Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
steveis here (guest)
Guest
Posts: n/a
hi i have a mini 2002 r50 it has been parked up for 2 years outside charged the battery and tried to start it it turns over no problem but no start fuel was very low maybe empty, put in 1 gallon put the fuel doesn't seem to be getting to the engine what could this be?
This post was auto-generated based upon a question asked on our tech article page here:
Old 03-22-2014, 07:21 AM
Nick at Pelican Parts's Avatar
I can't help without knowing what is missing from the system when you are trying to start it. When your engine doesn’t start you’ll want to check the basics. Check spark, fuel injector pulse and pressure fuel, volume and quality. Are there any fault codes? Once you figure out what is missing, it will be easier to diagnose.
- Nick
