Please can you let me know if I tune the overflow thube in will it lock at the top. I am not sure how deep the thube will go in to the drain boss.
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
It is either installed or not. Installed it helps to reach the correct level, removed it allows fluid to drain.
- Nick |
[QUOTE=Nick at Pelican Parts;8027729]It is either installed or not. Installed it helps to reach the correct level, removed it allows fluid to drain.OTE]
Thank you for the reply. I understand what this pipe does in the transmission. I need to know if you turn the pipe in does it lock at some point? If the pipe can go 5mm more in then that means at the current position the level in the transmission is not correct. Hope you can help? |
| All times are GMT -8. The time now is 05:55 AM. |
