Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Theo (guest)
Guest
Posts: n/a
Please can you let me know if I tune the overflow thube in will it lock at the top. I am not sure how deep the thube will go in to the drain boss.
This post was auto-generated based upon a question asked on our tech article page here:
Old 04-22-2014, 05:59 AM
Nick at Pelican Parts's Avatar
It is either installed or not. Installed it helps to reach the correct level, removed it allows fluid to drain.
- Nick
[QUOTE=Nick at Pelican Parts;8027729]It is either installed or not. Installed it helps to reach the correct level, removed it allows fluid to drain.OTE]
Thank you for the reply. I understand what this pipe does in the transmission. I need to know if you turn the pipe in does it lock at some point? If the pipe can go 5mm more in then that means at the current position the level in the transmission is not correct. Hope you can help?
Old 04-22-2014, 06:38 AM
