-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Subframe Removal (http://forums.pelicanparts.com/mini-discussion-forum/814239-question-subframe-removal.html)
Jim (guest) 06-02-2014 02:04 PM
Are all of the above steps required to drop the sub frame assembly the ~10mm for clearance when removing the transmission pan? I attempted to just loosen the main supporting bolts on the sub frame assembly but nothing was moving. I assume lots of the other steps you outline are holding things in place.
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 06-02-2014 02:04 PM
This tech article shows what is needed to remove the pan.
- Nick
