Guest
Posts: n/a
Are all of the above steps required to drop the sub frame assembly the ~10mm for clearance when removing the transmission pan? I attempted to just loosen the main supporting bolts on the sub frame assembly but nothing was moving. I assume lots of the other steps you outline are holding things in place.
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
This tech article shows what is needed to remove the pan.
- Nick |
