Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Sha (guest)
Guest
Posts: n/a
Hello. I have a 2004 Mini base. I'm trying to replace the fuel pump with a VDO replacement pump but I cant quite determine where all of the hoses are supposed to hook up. The gray line is still connected to a piece from the old fuel pump. Do I remove the piece and connect it where you had the gray hose? There are also 2 other hoses: a black and a brown. I appreciate any feedback you can give me.
This post was auto-generated based upon a question asked on our tech article page here:
Old 06-18-2014, 06:55 PM
Nick at Pelican Parts's Avatar
Are you replacing the fuel pump module or just the fuel pump? Just remove the old fuel pump, then reattach the hoses in the same orientation you removed them from.
- Nick
