Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
bdob (guest)
Guest
Posts: n/a
The water pump can be removed without removing the intake manifold, fuel rail and supercharger. Simply remove the water pump flange bolts with an extension through the gaps of the water pump. You can see the bolts by looking "through" the pump. Also using an open end wrench on the red vacuum connections helps. Use the open end wrench to push down on the red collar and pull up on the hose.
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-16-2014, 05:20 AM
Nick at Pelican Parts's Avatar
True, but that is pro technique and leaves little room for error. i would say most DIYers should stick to the factory procedure, for best results. Thanks for the additional info and feedback. We appreciate it.
- Nick
