Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
KEv (guest)
Guest
Posts: n/a
Hi Nick,
I replaced the rear brakes and sensor thanks for the help, and rest to 37000 miles, but the tach red "BRAKE" indicator light still comes on. I've tried all procedures. No luck. I double checked the sensor and wires. They look good. I heard the "click" when I reattached the sensor wire at the connnector underneath the back seat, so I think that is connected properly. Any ideas? Thanks
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-29-2014, 10:40 AM
Nick at Pelican Parts's Avatar
Did you check if the switch contacts at the parking brake lever are closing and opening properly? It is a simple switch and at times goes out of adjustment.
- Nick
Old 08-29-2014, 10:41 AM
