-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Clutch Replacement (http://forums.pelicanparts.com/mini-discussion-forum/828723-question-clutch-replacement.html)
Elementary Penguin (guest) 09-06-2014 06:05 PM
You list "lithium moly grease" to lubricate the shaft splines. I haven't been able to find "lithium moly grease" at least not in the same color as in the images. Can I use "white lithium grease"? Is it the same thing. Many thanks.
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 09-06-2014 06:05 PM
No, the clutch kit usually comes with the grease. Give our parts specialists a call at 1-888-280-7799. They can help you find the right grease.
- Nick
