Guest
Posts: n/a
You list "lithium moly grease" to lubricate the shaft splines. I haven't been able to find "lithium moly grease" at least not in the same color as in the images. Can I use "white lithium grease"? Is it the same thing. Many thanks.
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
No, the clutch kit usually comes with the grease. Give our parts specialists a call at 1-888-280-7799. They can help you find the right grease.
- Nick |
