Guest
Posts: n/a
I have a 2005 mini with a standard transmission that on occasion will not go into gear this usually happens at an intersection after coming to a stop. It takes a few tries to get it to go into gear. My dealer thinks I need a new clutch, but I think I have linkage or gear problems Also could low transmission oil be at fault? Any ideas?
Thanks, John __________________ This post was auto-generated based upon a question asked on our tech article page here: |
CHeck the hydraulic system, if it is OK, the clutch may be worn. Is the pedal high? I would suspect the hydraulic system.
- Nick |
