2006 Mini Gear Shift Issue
My wife was driving the Mini today
All was fine shifting then......putting it in first...it stalled Reving it she could get it going but all the other gears were like a spoon in a bowl of oatmeal...…..shift pattern was not correct She parked it and I drove it home Found no reverse gear......but lever in reserve was one of the higher gears While in gear can move lever side to side with no gear grinding Sounds like a shift cable went Did have some smell of clutch but does seem to be slipping Mini has only 90K miles |
914 Geek
Time to check the cables. They clip in and can sometimes get un-clipped, resulting in problems finding gears.
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Mini
Plan on doing from my search on the issue
914 Geek
Well, you could check here:
https://www.pelicanparts.com/techarticles/MINI/29-TRANS-Shift_Cable_Replacement/29-TRANS-Shift_Cable_Replacement.htm --DD
