Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Sebaie (guest)
Guest
Posts: n/a
Dear sir,
I have a Mini S 2009, I need to change the water pump because the old one got broken. My Question, Is it necessary to remove a the motor to change the water pump or I can do it by only removing the front-bumper and the carrier?? My whole aim is to not get close the car Motor..
Thank You
This post was auto-generated based upon a question asked on our tech article page here:
Old 10-28-2014, 04:47 PM
Nick at Pelican Parts's Avatar
You can replace the pump by removing the front carrier. You will have to remove the right side fender liner, as the pump in located on the right side of the engine.
- Nick
