-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Thermostat Replacement (http://forums.pelicanparts.com/mini-discussion-forum/840138-question-thermostat-replacement.html)
Reg (guest) 11-24-2014 03:30 PM
Nick, turns out there are two grommets/rubber insulators that the two upper mounting pins go through...and the grommets/insulators DO NOT come with the replacement radiator...they must be purchased separately. See the two attached pics. So now, no more movement...mounting problem solved!
http://www.pelicanparts.com/more_inf...50759-7132.jpg
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 11-24-2014 03:30 PM
Yes, those grommets should be removed from the old radiator, if in good shape. If not, replaced. Glad you got it worked out.
- Nick
