Guest
Posts: n/a
Nick, turns out there are two grommets/rubber insulators that the two upper mounting pins go through...and the grommets/insulators DO NOT come with the replacement radiator...they must be purchased separately. See the two attached pics. So now, no more movement...mounting problem solved!
![]() __________________ This post was auto-generated based upon a question asked on our tech article page here: |
Yes, those grommets should be removed from the old radiator, if in good shape. If not, replaced. Glad you got it worked out.
- Nick |
