Guest
Posts: n/a
My 2005 mini cooper S will run perfectly for about 30-45 minutes then go off. It will always restart but never runs more than 5 minutes each time until it is left to cool for about 30 minutes, then the sequence starts again. Temperature gauge is normal. i just replaced the fuel filter.
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
Could very well be a fuel pump, or an engine sensor. I can't help without knowing what is missing from the system when you are trying to start it. When your engine doesn’t start you’ll want to check the basics. Check spark, fuel injector pulse and fuel pressure, volume and quality. Are there any fault codes? Once you figure out what is missing, it will be easier to diagnose.
- Nick |
