Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
I just rebuilt the motor in my 2006 MCS and tried to turn it over for the first time, all the bells and whistles came on in the cabin but when I turned the key nothing happened. I checked the starter and it works fine. Any suggestions?
This post was auto-generated based upon a question asked on our tech article page here:
Old 12-19-2014, 04:02 PM
Nick at Pelican Parts's Avatar
I can't help without knowing what is missing from the system when you are trying to start it. When your engine doesn’t start you’ll want to check the basics. Check spark, fuel injector pulse and fuel pressure, volume and quality. Are there any fault codes? Once you figure out what is missing, it will be easier to diagnose.
- Nick
