Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Mat (guest)
Guest
Posts: n/a
I have a 2006 Cooper, 5 forward speed manual transmission. Lately, while in gear, the RPM will increase with no acceleration. Light pressure on the gas does not cause this issue, but a harder press does. Is this fluid level or a more serious problem. Clutch and shifting is smooth in all gears including R. I have not seen any fluid leaks below the car.
This post was auto-generated based upon a question asked on our tech article page here:
Old 01-16-2015, 05:24 AM
Nick at Pelican Parts's Avatar
Sounds like the clutch is worn and slipping.
- Nick
