Guest
Posts: n/a
I have a 2006 Cooper S, i already change the fuel pump, and now the problem is that it dont start in the girst try, you have to try angain and again until in the fourth or fifth try it start, once on the car works great, any sugestion!
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
I can't help without knowing what is missing from the system when you are trying to start it. When your engine doesn’t start you’ll want to check the basics. Check spark, fuel injector pulse and fuel pressure, volume, quality and engine compression. Are there any fault codes? Once you figure out what is missing, it will be easier to diagnose.
- Nick |
