Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
hot shot (guest)
Guest
Posts: n/a
I recently purchased a 2007 mini. The seller installed new struts. The issue is in the front.The springs don't sit on the strut plate. It doesn't appear that they were installed properly.
This post was auto-generated based upon a question asked on our tech article page here:
Old 01-22-2015, 06:48 AM
Nick at Pelican Parts's Avatar
You will have to remove the struts and inspect then. If needed, compress the springs and adjust the spring hat.
- Nick
