-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Clutch Master and Slave Cylinder Replacement (http://forums.pelicanparts.com/mini-discussion-forum/852137-question-clutch-master-slave-cylinder-replacement.html)
daughtershelper (guest) 02-17-2015 11:00 AM
After changing the clutch on a 2004 Mini Cooper and as far as the clutch is concerned everything was fine with that part of the car but now it is only running on 2 cylinders. It was suggested that I reset the ECU and I have completed that. The problem continues. Any suggestions? It has a P2300 Low Voltage on coil message.
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 02-17-2015 11:00 AM
Check voltage at the coil. You may have shorted or pinched wires during the repair.
- Nick
