| Guest
					Posts: n/a
			After changing the clutch on a 2004 Mini Cooper and as far as the clutch is concerned everything was fine with that part of the car but now it is only running on 2 cylinders.  It was suggested that I reset the ECU and I have completed that.  The problem continues.  Any suggestions?  It has a P2300 Low Voltage on coil message. __________________ This post was auto-generated based upon a question asked on our tech article page here: | ||
|  02-17-2015, 11:00 AM |
| Moderator Join Date: Jul 2012 Location: New England
			Check voltage at the coil. You may have shorted or pinched wires during the repair.  - Nick | ||
