Will the shifter cable rattle where it connects to the stick? I am getting a avery annoying rattle and it only happens in 2nd and 4th gears, or at idle in neutral, and I can replicate the rattle by jiggling the shifter. It sounds like it is coming from right below the shifter. Sounds like a nut is loose and a waters is rattling around.
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
I don't believe I have ever seen that. If you pinpointed the area of the rattle, your best bet is to physically inspect the area.
- Nick |
