Guest
Posts: n/a
2004 mini manual..car drove perfectly fine. I parked it in the drive then agent back outside to start abd the pedal went to the floor and stayed. Also got a squealing noise..I replaced the leaky slave cylinder and bled it.. my pedal is spongy and car won't go into gear at all. The arm going into the transmission the arm the slave cylinder moves is a bit sloppy going into the top of the transmission. Any ideas?
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
I would try bleeding the system again. It is common to have to bleed it multiple times. Also, be sure the slave is in good condition.
- Nick |
