-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Shift Cable Replacement (http://forums.pelicanparts.com/mini-discussion-forum/862087-question-shift-cable-replacement.html)
aaron (guest) 04-23-2015 09:14 AM
hi, i have a 04 mini cooper S. I stopped at a light and when i went to go put the car into first gear, and all that went up are the RPMs. I can put the shifter into any gear, and the car does nothing. it doesnt even stall out if i take my foot off the clutch and do not press the gas. the car stays on, but its almost as if the car is in neutral.
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 04-23-2015 09:14 AM
Check if the shift cables came off.
- Nick
Dave at Pelican Parts 04-24-2015 07:36 PM
Also check the clutch hydraulics; the master cylinder attached to the pedal and the slave cylinder at the transmission end. If none of the above are the problems, you may have a bad clutch.
--DD
