Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
logan (guest)
Guest
Posts: n/a
Cruise control on my r53 no longer works. I've heard that this could be related to the clutch safety switch. Should this be the first thing I try? Thanks!
PS I accidentally posted this on the inner ball joint page a bit ago. Sorry about that.
This post was auto-generated based upon a question asked on our tech article page here:
Old 05-12-2015, 05:29 AM
Nick at Pelican Parts's Avatar
hard to say. It could be the issue. You can check it to see if the signal is faulty, before replacing it. However, checking the DME for fault codes and monitoring the cruise inputs is also a good place to start.
- Nick
