Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
MINIJCW07 (guest)
Guest
Posts: n/a
Doing a expansion tank replacement on my 07' JCW. I came across the part GROMMET that is used for the bottom insertion of the reservoir, it points out to the front. My question is where does the grommet go into? Is it necessary? And whats the grommet used for? I feel that when I pulled off the reservoir I might of pulled it off a bit to hard and the grommet fell down. I've added a picture for a better view of the question I'm asking?
This post was auto-generated based upon a question asked on our tech article page here:
Old 06-02-2015, 05:12 AM
Nick at Pelican Parts's Avatar
There is a plastic pin at the bottom of the reservoir, this pin sits in the rubber grommet at the base, in the radiator support.
- Nick
