-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Window Regulator Replacement (http://forums.pelicanparts.com/mini-discussion-forum/870406-question-window-regulator-replacement.html)
Challo (guest) 06-12-2015 11:40 AM
Is there a special way to remove the motor from the regulator? I bought a second hand regulator but the motor is knackered. The Motor on the old regulator is good so I want to swap over.
When I removed the good motor from the broken regulator the gearbox came off and released all the cables. Anyway to get around it?
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 06-12-2015 11:40 AM
Remove the fasteners, then twist as you pull up.
- Nick
