Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Connor (guest)
Guest
Posts: n/a
Hello,
When I went to fill my reservoir tank, I was only able to get about 3 liters in the system before it stopped filling up. I drained about 5 or 6 liters of coolant out of the system so I know there was at least that much in there when I started. I've tried opening and closing both bleeder screws with the engine on and no luck getting any into the system. The top hose doesn't heat up, so I don't think coolant is flowing. Any ideas?
This post was auto-generated based upon a question asked on our tech article page here:
Old 06-18-2015, 05:56 AM
Nick at Pelican Parts's Avatar
Sounds like trapped air. Can you share a photo of the tank you are filling?
- Nick
