Guest
Posts: n/a
I am a little confused by this DIY. Is a special tool required to change the belt on an R56 cooper S? From what you say here it looks like its just a 30 mm box wrench is that correct?
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
There is a tool, but a wrench will do. See this tech article for a method without front end disassembly:
http://www.pelicanparts.com/techarticles/MINI_R56/03-ENGINE-Drive_Belt_Replacement/03-ENGINE-Drive_Belt_Replacement.htm ] http://www.pelicanparts.com/techarticles/MINI_R56/03-ENGINE-Drive_Belt_Replacement/03-ENGINE-Drive_Belt_Replacement.htm [/url] - Nick |
