Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Vito (guest)
Guest
Posts: n/a
Hey nick I have 2006 Mini Cooper s I run off the fuel and now won't star I check the fuse is geting Fire but is not geting Fire to the fuel pump I jump a wire whit 12 volt and run good you know if have a fuel cut off or a reset fuel pump I look everywhere I can't not f
This post was auto-generated based upon a question asked on our tech article page here:
Old 06-29-2015, 06:42 PM
Nick at Pelican Parts's Avatar
No reset. You may have ruined the pump running it dry. I would perform a fuel delivery system test. Check fuel pressure, volume and quality.
- Nick
