Guest
Posts: n/a
Hey nick I have 2006 Mini Cooper s I run off the fuel and now won't star I check the fuse is geting Fire but is not geting Fire to the fuel pump I jump a wire whit 12 volt and run good you know if have a fuel cut off or a reset fuel pump I look everywhere I can't not f
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
No reset. You may have ruined the pump running it dry. I would perform a fuel delivery system test. Check fuel pressure, volume and quality.
- Nick |
