Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
scratchyhead (guest)
Guest
Posts: n/a
Could you tell me how far the lever that attaches to the clutch moves when depressing the clutch pedal. Mine moves about 1"and doesn't disengage the clutch even after replacing the slave cylinder. Does it point towards a new clutch or a new master cylinder. I would really find it helpful if i know how far over its supposed to go.
This post was auto-generated based upon a question asked on our tech article page here:
Old 07-17-2015, 09:53 AM
Nick at Pelican Parts's Avatar
It won't move much more than that, due to the stroke of slave piston. You may have air the system or a faulty clutch. if moving, most likely a faulty clutch.
- Nick
