Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Rob (guest)
Guest
Posts: n/a
Hi Nick,
I've found your knowledge of the mini to be impressive. With that said, I have a 2008 clubman non s model and have a coolant leak on the thermostat housing side. A dye test proved to be inconclusive. I am therefor looking to replace the thermostat housing itself but am having a difficult time finding the correct housing for the replacement. Any help on what I should be looking for is greatly appreciated, such as am I looking for a R55 or R 56 thermostat housing? I'm confused to as what these numbers refer to when I am searching for parts.
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-17-2015, 06:20 AM
Nick at Pelican Parts's Avatar
You need the second generation housing. Just be sure the coolant pipe at the back of the engine (under the intake manifold) isn't leaking. Should have a DiY for these repairs in the coming weeks. Stay tuned.
I’m not the best with part numbers.
Give our parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
