Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
kevin (guest)
Guest
Posts: n/a
I have an 08 mini with the 1.6 dohc non turbo non supercharged and i have an issue i thought was low side fuel. I have 55 psi at the shrader. It is a start/stall issue and when you give it gas hit the pedal it can idle out of it if the rpm is higher. changed air filter, fuel filter is lifetime, and plugs are nice and tan/brown. Thinking its hpp. thoughts?
This post was auto-generated based upon a question asked on our tech article page here:
Old 09-22-2015, 08:11 AM
Nick at Pelican Parts's Avatar
What is fuel volume and how does the quality look?
- Nick
