Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
OBD P113C Code
Has anyone else gotten a P113C code as a fault from the OBD readout? After the check engine light came on I had the code pulled a two different parts houses and both gave a P113C code with no other explanation. I haven't been able to find a cross reference with this code to find out what it's pointing to. It's not in the Bentley book (and even looks like the wrong format- 4 numbers vs. 3 numbers and a letter), and I haven't found anything on the web. The closest I've come is what appears to be an explanation on the iATN website, but it's a service for pros and you need to be a paid subscriber to read the response.
Does anyone know what P113C represents on a 2006 Mini Cooper S?
Tim
'69 911e (work in progress)
‘20 Honda Ridegeline
'22 Subaru BRZ
Restoring Jewel's 911e
Old 10-13-2013, 10:57 AM
Administrator
Luccia at Pelican Parts's Avatar
(Late to the thread, but wanted to update for anyone else who has this error). It's been linked as an O2 sensor code. Are you using a generic code reader? I believe O2 codes range from P1132 - P1139 and the code you're getting is more of a generic reading with a non-specific BMW/MINI code reader.
Old 10-02-2015, 10:09 AM
