Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Brian (guest)
Guest
Posts: n/a
Is there a way to bleed the system without a pressure bleeder?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Clutch Master and Slave Cylinder Replacement
Old 11-04-2015, 12:25 PM
Nick at Pelican Parts's Avatar
Yes. you can gravity bleed it first. Then, use the clutch pedal while helping the slave cylinder push the clutch fork. Repeat until bled.
- Nick
