Guest
Posts: n/a
Your excellent write up on the valve cover gasket replacement directs us here to see about removal of intercooler and fuel rail for an S - but I can't tell just how far I need to go with the steps here. Can you indicate through which step we need to go just to be able to do the valve cover gasket repair? Thanks and hope that makes sense.
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - R53 Water Pump Replacement |
Just remove the items until you can see the entire valve cover and fasteners. The entire intercooler will have to come off for starters.
- Nick |
