Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
R spear (guest)
Guest
Posts: n/a
I have changed injectors spark plugs and fuel filter in pump car will run but no throttle and stumbles alot
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Fuel Pump and Filter Replacement
Old 11-30-2015, 07:29 AM
Nick at Pelican Parts's Avatar
Is the check engine light on? Sounds like an engine misfire. I would check spark, fuel and compression on all cylinders.
- Nick
