-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Battery and Connection Notes Replacement (http://forums.pelicanparts.com/mini-discussion-forum/894906-question-battery-connection-notes-replacement.html)
Ryan (guest) 12-14-2015 05:56 AM
If we replace the battery with one of the exact same specs, would we still need to register the new battery or will the charge cycle etc. be the same?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article - Mini R56 - Battery and Connection Notes Replacement
Nick at Pelican Parts 12-14-2015 05:56 AM
Yes. registration has to do with age of battery as well as size.
- Nick
Dave at Pelican Parts 12-14-2015 06:54 AM
But it is only needed if your car has the Intelligent Battery Sensor. IBS cars have a plastic "box" on the battery ground cable, as shown in the following image:
http://www.pelicanparts.com/techarticles/MINI_R56/23-BASICS-Battery_and_Connection_Notes_Replacement/images_med/pic07.jpg
If you do not have that on your car, you should not need to register the battery at all.
--DD
