Guest
Posts: n/a
Do you have a similar article for r/52/53? I've a leaky seal on passenger side after 6k miles on a new cv axel ... Tiring to determine if this is doable without dropping the trans to get it done.
Thanks! __________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article - Mini R56 - Drive Axle Seal Replacement |
We don't currently have that tech article. If we get a chance to perform the procedure, we will be sure to document it. I would grab a repair manual. It will have the procedure, special tools and torque specs. Give our parts specialists a call at 1-888-280-7799. All R52 articles are here: http://www.pelicanparts.com/techarticles/MINI/MINI_tech_index.htm#basics ] http://www.pelicanparts.com/techarticles/MINI/MINI_tech_index.htm#basics [/url] - Nick |
