Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
James (guest)
Guest
Posts: n/a
Why is it a requirement to move the exhaust pipe? it looks like there is enough clearance to removed the pan bolts and then slide the pan down as you show in figure 12.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article - Mini R56 - Oil Pan Gasket Replacement
Old 01-05-2016, 07:42 AM
Nick at Pelican Parts's Avatar
There is not enough room to access the pan, fasteners or get the pan out.
- Nick
