2007 MINI R56 FRICTION WHEEL OK ON START UP , AFTER ABOUT 2 MIN FRICTION WHEEL RELEASES AHD WATER PUMP STOPS TURNING . NEW FRICTION WHEEL FITTED AND JUST THE SAME AS THE OLD ONE
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article - Mini R56 - Friction Wheel Replacement |
If the drive belt tensioner OK? Possible the belt is moving, pushing it down. Be sure the pull tab is seated correctly as well.
- Nick |
| All times are GMT -8. The time now is 12:20 AM. |
