Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
ALDY (guest)
Guest
Posts: n/a
2007 MINI R56 FRICTION WHEEL OK ON START UP , AFTER ABOUT 2 MIN FRICTION WHEEL RELEASES AHD WATER PUMP STOPS TURNING . NEW FRICTION WHEEL FITTED AND JUST THE SAME AS THE OLD ONE
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article - Mini R56 - Friction Wheel Replacement
Old 01-07-2016, 06:53 AM
Nick at Pelican Parts's Avatar
If the drive belt tensioner OK? Possible the belt is moving, pushing it down. Be sure the pull tab is seated correctly as well.
- Nick
