Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
MGM (guest)
Guest
Posts: n/a
Hello. I cannot figure out how to pull the plastic clip out fig 5. It appears to be threaded in but I cannot unscrew it anticlockwise since it hits the valve cover. How do I "Pull the clip up and off of the mounting stud"?
Also, how do I remove the hose clamps on the inlet and return hoses from Power Steering reservoir.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Valve Cover Gasket Replacement
Old 01-22-2016, 05:50 AM
Nick at Pelican Parts's Avatar
It has to be pulled straight up. It has serrated teeth that grab the stud threads.
- Nick
