Is there an electrical schematic of the camshaft sensor
So as to test the sensor using a multimeter? I don't have a wide range of tools but I have a scan Guage II Which shows a P0340 code and I have a multimeter. If I could Find an electrical diagram of the camshaft sensor I Might be able to verify it is truly faulty. __________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article - Mini R56 - Camshaft Sensor Replacement |
I would grab a repair manual. It will have the wiring.
Give our parts specialists a call at 1-888-280-7799. Procedure here: http://www.pelicanparts.com/techarticles/MINI_R56/18-FUEL-Camshaft_Position_Sensor_Testing/18-FUEL-Camshaft_Position_Sensor_Testing.htm ] http://www.pelicanparts.com/techarticles/MINI_R56/18-FUEL-Camshaft_Position_Sensor_Testing/18-FUEL-Camshaft_Position_Sensor_Testing.htm [/url] - Nick |
| All times are GMT -8. The time now is 06:51 AM. |
