Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Jay (guest)
Guest
Posts: n/a
Is there an electrical schematic of the camshaft sensor
So as to test the sensor using a multimeter?
I don't have a wide range of tools but I have a scan Guage II
Which shows a P0340 code and I have a multimeter. If I could
Find an electrical diagram of the camshaft sensor I
Might be able to verify it is truly faulty.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article - Mini R56 - Camshaft Sensor Replacement
Old 01-29-2016, 08:33 AM
Nick at Pelican Parts's Avatar
I would grab a repair manual. It will have the wiring.
Give our parts specialists a call at 1-888-280-7799.
Procedure here:
http://www.pelicanparts.com/techarticles/MINI_R56/18-FUEL-Camshaft_Position_Sensor_Testing/18-FUEL-Camshaft_Position_Sensor_Testing.htm ] http://www.pelicanparts.com/techarticles/MINI_R56/18-FUEL-Camshaft_Position_Sensor_Testing/18-FUEL-Camshaft_Position_Sensor_Testing.htm [/url]
- Nick
