Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Gerby (guest)
Guest
Posts: n/a
Hi I drive a mini cooper s 2006 model eml just went on and the car lost its power and stopped and did not start since then...
What can be the problem?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Crankshaft Pulley Replacement
Old 02-06-2016, 12:07 PM
Nick at Pelican Parts's Avatar
Could be a faulty throttle housing or belt slip. I would start by checking the DME for fault codes. If the system is not working properly, a fault code will be set. This will be your best bet when diagnosing.
- Nick
