-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Turbocharged Engine Timing Chain Guides Replacement (http://forums.pelicanparts.com/mini-discussion-forum/900476-question-turbocharged-engine-timing-chain-guides-replacement.html)
r56 (guest) 01-29-2016 08:35 AM
Hello! In the last step you wrote "rotate engine one full rotation" - I should just do 360 degree rotation with crankshaft pulley bolt?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article - Mini R56 - Turbocharged Engine Timing Chain Guides Replacement
Nick at Pelican Parts 01-29-2016 08:35 AM
yes, 360° until you can line the marks up again and check your work.
- Nick
Dave at Pelican Parts 01-29-2016 08:18 PM
Wouldn't that mean 2 crankshaft rotations, one camshaft rotation?
--DD
David Floyd 01-30-2016 09:01 AM
In a related note further into the replacement, figure 15 in the how to shows the 2 lower guide bolts exposed, the rear on mine is covered, has a pull cord that will allow some movement, does the tensioner have to come off?
Edit... Answer is the Waterpump friction wheel has to come off for guide bolt removal
http://forums.pelicanparts.com/uploa...1454173148.jpg
