Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
r56 (guest)
Guest
Posts: n/a
Hello! In the last step you wrote "rotate engine one full rotation" - I should just do 360 degree rotation with crankshaft pulley bolt?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article - Mini R56 - Turbocharged Engine Timing Chain Guides Replacement
Old 01-29-2016, 08:35 AM
Nick at Pelican Parts's Avatar
yes, 360° until you can line the marks up again and check your work.
- Nick
914 Geek
Wouldn't that mean 2 crankshaft rotations, one camshaft rotation?
--DD
Old 01-29-2016, 08:18 PM
Shade Tree Mechanic
David Floyd's Avatar
In a related note further into the replacement, figure 15 in the how to shows the 2 lower guide bolts exposed, the rear on mine is covered, has a pull cord that will allow some movement, does the tensioner have to come off?
Edit... Answer is the Waterpump friction wheel has to come off for guide bolt removal
Old 01-30-2016, 09:01 AM
